Unable to connect Android phone to Mac without USB
I’m trying to move some photos from my Android phone to my Mac without USB because I don’t have a cable with me. Both are on the same Wi-Fi network, but the phone doesn’t show up anywhere on the Mac for browsing files. I expected there to be a wireless connection option, but I’m not seeing one. Does anyone else see this, or am I missing a setting that makes the phone accessible?
I’d start with MacDroid if convenience is the priority for wireless Android-to-Mac transfers. For a small file, I’d keep it simple and email it to myself instead.
The distinction I’d make is whether I want a connection between the devices or just a way to get a file from one to the other. That’s a more useful starting point than treating every option as interchangeable.
Connect the devices
For the dedicated-app route, install the MacDroid app on your Mac, then follow its instructions for connecting your Android wirelessly. Once connected, you can transfer files. It’s the convenience-focused choice here, though I wouldn’t turn that into a claim about transfer speed.
FTP is another route over your local network. On Android, install an FTP server app, such as ES File Explorer, set it up, and note its FTP address. On the Mac, use an FTP client such as Filezilla to access that address and move files. I’d choose this if I were comfortable handling the server-and-client setup.
For a simpler connection method, enable Bluetooth sharing by turning Bluetooth on for both devices, pairing them, and using Bluetooth file sharing. The catch is that large files may transfer slowly.
Skip the direct connection
Google Drive and Dropbox let you take the cloud-storage route: upload files from Android, then download them on your Mac. You’re moving files through storage rather than pairing the devices.
Email follows a similar handoff. Send yourself the files from your phone, then open the message and download them on the Mac. It’s a good fit for small files, which is why I’d keep it in mind before setting up something else.
Are you moving large files between these devices, or mostly sending yourself small ones?
The downside to using apps specifically for this is that there is still some setup on your phone to do here. This setup includes enabling developer options and debugging on your Android phone. Enable wireless debugging, under Android 11+ and then click pair device with pairing code. Finally click the pairing option on your Mac under MacDroid.
We would suggest using MacDroid as it allows you to pair your phone via finder. This means you will be able to easily view the files from your phone. For these photos we would recommend copying them to a folder on your Mac. Open up a couple to ensure nothing is going to be deleted off your phone. This is just a copy over initially.
Being on the same Wi-Fi doesn’t automatically make your phone available for file browsing. With MacDroid, you establish the wireless connection in the app first, rather than waiting for the phone to appear in Finder. That’s a distinction I’d make with @jackson’s instructions.
I would use MacDroid here. But before spending time repeating the pairing steps, I’d check what kind of Wi-Fi you’re connected to.
A guest, hotel, or public network can let both devices access the internet while blocking them from communicating with each other. This is usually called “client isolation” or “AP isolation.” So seeing the same network name on both screens isn’t enough to rule out a network problem.
If this is your home network, try putting both devices on the main network rather than the guest network. If it’s a managed network, ask whether connections between devices are allowed. I wouldn’t start changing security settings on a network you don’t control. Google’s troubleshooting guidance specifically flags isolated guest and public networks as a barrier to local device connections.
For troubleshooting, I’d separate “the phone hasn’t been connected through an app yet” from “the app’s pairing attempt fails.” Your description sounds like the first situation so far. I wouldn’t treat the empty Finder sidebar alone as evidence that anything is broken.
If you want the pictures in Apple Photos, plan on importing them after the wireless transfer. In Photos, choose File > Import and select the downloaded pictures or their folder. That’s a separate step from getting the files onto your Mac.
I would use MacDroid for the transfer. Following @jackson’s suggestion to copy into a folder, I’d give that folder an obvious name like “Phone photo transfer” rather than mixing everything into Downloads. Keep the destination simple while you’re sorting out the connection.
Once you decide whether you want to add regular images to your Mac, or those stored within Photos, just stop importing once they have been added to the folder of your choice. If importing to a folder, you can import that folder later. This will help avoid any issues with setting up your photo library.
If you’re willing to select the photos on your phone, I’d skip the Finder setup and use LocalSend. It’s free, runs on Android and macOS, and transfers over your local network without a cloud account. That’s the route I’d pick for this job.
The developer-options advice from @jackson is specific to that connection method. I wouldn’t treat it as the starting point for every wireless transfer. LocalSend’s setup is simply to install and open it on both devices, select your photos on Android, and choose the Mac as the recipient. No debugging setup is part of that workflow.
You’re sending selected files rather than setting up phone storage to browse. That distinction matters here: I’d rather select the pictures where I can already see them than configure remote browsing just to retrieve them. LocalSend saves received files to Downloads by default, though you can change the destination in its settings.
If the Mac doesn’t appear inside LocalSend, check whether the app has Local Network permission in macOS privacy settings. Its own troubleshooting instructions flag that permission as a possible cause of missing devices. I’d check that before reinstalling anything.
If you have stored the images within Google Photos then you can download them directly by opening Google Photos on your Mac, logging into the same account, and selecting the images you wish to download. Select ‘Download’ from the drop down menu. You don’t need to pair your phone.
Differences in image quality may occur. If ‘Storage saver’ has been enabled on your Photos account, then the image may be compressed and the resolution reduced. To check what quality the image you are downloading is in your backup, open the information panel on the image. If it says ‘Original Quality’, then no changes to resolution and image quality will have taken place. It is important to note these words rather than just assume they look fine.
I’m with @cyberwizard3792studi on skipping the remote-browsing project for this task. My preference would be to use an existing backup if it meets your needs, or transfer the phone’s files directly if you want the originals. I wouldn’t set up a whole new cloud backup just to avoid setting up a transfer app. That’s replacing one chore with another.
Skip ES File Explorer for the FTP idea. That app got pulled from the Play Store a while back over ad fraud stuff, and I wouldn’t hand it filesystem access just to move a few photos. If you want FTP there are cleaner server apps, but honestly FTP is the most fiddly route on this whole list for what you’re trying to do.
For a handful of photos with no cable, @cyberwizard3792studi has the right instinct. LocalSend is quick because you pick the pictures on the phone where you can already see them, and nothing touches a cloud account. The only snag I’ve run into with that style of app is the Local Network permission prompt on macOS, which is easy to dismiss by accident and then the Mac just never shows up. So if it goes quiet, that’s the first place to look.
Where MacDroid earns its keep over Bluetooth is that it copies the actual original files, no silent downscaling on the way across, which matters if these are photos you care about keeping full resolution. @quantum_cipher624 is also right that the empty Finder sidebar means nothing on its own. Being on the same network and being allowed to talk to each other are two different things, and guest networks love to block that quietly.
If you just need the shots off the phone today and don’t care about a repeatable setup, select them and send. Save the whole pairing project for when you actually want ongoing access to the phone’s storage.
