I’m looking for a reliable alternative to USB Over Network software because the current program I’m using is causing connection drops and device recognition issues. Has anyone found a better solution for sharing USB devices over a network that works smoothly and is easy to set up? Any recommendations or experiences would be really helpful.
Fabulatech flashes that price tag—$599.95. For just EIGHT devices.
Flip the coin, and USB Network Gate rolls in way lighter on the damages. First of all, the app is free for 1 device. Depending on the license, you’re talking a fraction of the cost (I did the math, and honestly, buying three or four licenses of USB Network Gate is still cheaper than one Fabulatech seat). If you’re budget conscious (or, you know, sane), that difference is straight-up eye-watering.
I wanted to use my USB gear while remoting in over RDP. With Fabulatech, you DO NOT get this in the main package. They push you into a corner, forcing you to buy a whole separate product line.
Meanwhile, USB Network Gate - You just install, share, and connect. No extra hoops. For me, that might be the clincher.
USB Network Gate comes with everything you want right from the start. File sharing, RDP, encryption, whatever—you install it, and it does the job.
Oh—one more thing. If you’re thinking about handling USB peripherals with Android tablets or phones, keep your eyes peeled. With USB Network Gate, though, it’s like someone finally remembered the world runs on mobile now.
USB Network Gate might look like a heavyweight app (it’s not small—just warning), but you get a buffet of features, broader device support, and you don’t have to sell your bike to afford it.
If you’ve spent more time wrestling with “USB device not recognized” errors than actually getting work done, you’re not alone. USB device sharing over network is infamous for random dropouts and flaky connections—especially with certain popular tools (lookin’ at you, Fabulatech and that price tag). I see @mikeappsreviewer already did a teardown between Fabulatech and USB Network Gate, and while he’s not wrong about some key pain points, it’s not always as easy as just swapping one for the other.
Let’s lay it out simple: If you want a truly stable solution for remote USB device sharing across LAN/WAN, USB Network Gate is a top contender for a reason. It’s a heavy install but covers Windows, Mac, Linux, and even Android. Remote Desktop support comes baked in (unlike Fabulatech’s bolted-on extra cost) and yeah, the setup isn’t rocket science.
But hey, if neither works for you or you just want something free and open-source, look into VirtualHere. It’s lightweight, has a simple client/server model, and works great with Raspberry Pi as a USB device server (if that’s up your alley). Not as many bells and whistles, but for casual or occasional sharing? It’s solid, especially if you’re DIY-minded.
If constant disconnects are ruining your day, and you need seamless plug-n-play with broad device support, consider exploring reliable USB device sharing solutions for networks like USB Network Gate. It’s not perfect, but until someone makes a magical universal dongle for the 21st century, it’s the best balance I’ve found between cost, compatibility, and stability. Stay skeptical, though—no one-size-fits-all answer here. Always test with your actual gear before forking out cash.
If software’s flaking out for you, sometimes the BEST thing isn’t another software—it’s hardware. Dedicated USB-over-IP hubs are pricey but can be rock-solid. I’ve got a Silex DS-510 in the lab that’s run for months without hiccups (zero software to crash). Biggest pain: compatability can be hit/miss outside Windows, and device driver weirdness with stuff like dongles or audio interfaces, so YMMV.
On the DIY/nerdier end, there are open-source options like VirtualHere (already mentioned, but for real—if Raspberry Pi isn’t just a buzzword in your house, you might love it). But downside is very basic feature set, so if you need device-specific passthrough (like licensing dongles, smartcards, or webcams with audio), it can be super finicky.
Sometimes RDP “USB redirection” (especially through Windows Remote Desktop or VMWare) works for basic things like printers, drives, maybe some generic stuff. But anything finicky (Wacom tablets, crazy lab gear)? Forget it. You’ll spend more time cursing than working.
If you’re in a corporate/enterprise setting, look for FlexiHub as USB sharing alternatives, but keep in mind they can run into similar stability quirks or licensing confusion (and sometimes security/privacy flags depending on how sensitive your data is).
And not everyone agrees, but I’ve found USB Network Gate to be the most reliable blend of features vs config agony. It’s bulky, but works with everything I’ve thrown at it (Windows and Linux here).
If you want to try it for yourself, here’s a more direct option for exploring the most robust USB device sharing downloads right now.
No “magic” bullet, but if you just want it to work and don’t care about an extra background process or two: USB Network Gate is the way I’d go.
Use a powered USB switch instead of USB-over-network software. Plug the device into the switch, connect two computers, then press one button to change ownership. This removes network drops, licensing, background services, and remote device detection issues.
Choose a switch with its own power input, especially for hard drives, webcams, audio gear, or scanners. Confirm USB 3.x support and enough bandwidth for your device. It works best when both machines sit nearby. Setup takes a few mintues, and troubleshooting stays simple. For longer distances, pair it with an active USB extension cable.
A powered USB switch isn’t really a network solution, @darkhive7465node, it just hands one port between two machines sitting next to each other. The second you need actual distance or more than two PCs, you’re back to software like USB Network Gate anyway. Fine as a workaround, not a replacement.
