What’s the best way to clean up photos on iPhone?
My iPhone Photos app has gotten cluttered with duplicates, screenshots, and old images, and now it’s eating up storage. I’m looking for the easiest way to organize, delete, and back up iPhone photos without losing anything important.
The biggest thing I’d avoid is trying to clean the whole library by hand in one marathon session. I did that with roughly 35,000 photos and videos, and it was miserable. After hours of scrolling, selecting, and deleting, it barely felt like anything had changed.
What helped was breaking the cleanup into smarter passes.
Start with the Photos app for the obvious stuff. If you’re deleting random photos you already know you don’t want, it’s still the simplest tool. Use swipe-select instead of tapping every item one at a time. Also, don’t only work from the main Library view. Going album by album is way easier because you can focus on one type of junk at a time.
Some albums also have a Select All option, which is worth using when the whole album is disposable. Screenshots are a good example. If you open an album and know most of it can go, Select All saves a lot of pointless tapping.
Where the Photos app started to fall short for me was duplicates and “almost duplicates.” The built-in Duplicates album is fine for exact copies, but that wasn’t my real problem. I had bursts, ten versions of the same shot, old screenshots, Live Photos I didn’t care about anymore, and big videos taking up most of the storage.
That’s when I used Clever Cleaner, and that made the cleanup much faster.
The useful part was that it grouped similar photos, not just exact duplicates. It also separated screenshots, found large videos, suggested the best photo in a group, and let me turn Live Photos into normal still images if I didn’t need the motion part. Instead of scrolling through tens of thousands of individual photos, I was reviewing smaller groups that actually made sense. The swipe-based review helped too, since you’re deciding by group instead of staring at every single image.
I still checked things before deleting them, but the app handled most of the sorting. What looked like it would take a few weekends ended up being more like a couple of evenings.
If you’re trying to lower iCloud storage too, keep in mind that iCloud Photos is the same synced library. Deleting something from your iPhone also removes it from iCloud Photos and your other synced devices. That’s fine if you mean to delete it, but it’s not the same as just removing a local copy from the phone.
Also, empty Recently Deleted after a big cleanup. A lot of people skip that part. Until those items are actually removed from Recently Deleted, they can still take up storage, so your iCloud usage may not drop the way you expect.
After duplicates, I’d go straight for the biggest storage offenders. In my case, those were:
  1. long videos I had forgotten about
  2. screen recordings
  3. old screenshots
  4. Live Photos
  5. random images and videos saved from messaging apps
Deleting a handful of large videos did more for storage than deleting hundreds of normal photos.
One thing that made the final cleanup easier was using a computer. After I got rid of the obvious junk, I connected the iPhone to my Mac and did the more careful sorting on a bigger screen. Comparing similar shots and organizing albums is just less annoying that way.
If I were doing the whole thing again, I’d do it like this:
  1. Use Photos first for easy deletes, especially albums where Select All makes sense.
  2. Use Clever Cleaner for duplicates, similar shots, screenshots, large videos, and Live Photos.
  3. Empty Recently Deleted so the storage is actually freed.
  4. Do the picky sorting on a Mac or PC if you have one.
  5. Spend 10 to 15 minutes every week cleaning up new screenshots, blurry shots, and duplicates before they pile up again.
That last part matters more than it sounds. The cleanup is way less painful when you don’t let the library grow into a giant mess again.
Back up first, clean second. Before using Photos or any cleaner app, make sure iCloud Photos, a Mac import, Google Photos, or an external drive has a real copy of anything you care about, because “sync” and “backup” get confused a lot.
After that, I’d do the risky deletes in small batches and leave Recently Deleted alone for a day or two before emptying it. It gives you a safety net if the app grouped something badly or you were too aggressive.
The sneaky downside is that “cleaning up” can wreck your organization if you delete from albums without realizing the photo still lives in the main library, or if you remove something from the library and it disappears from every album it was in. I agree with @waldgeist on backing up first, but I’d spend five minutes checking how your library is actually set up before deleting anything: shared albums, favorites, hidden photos, and imports from messages can behave differently than people expect. My lazy method is to sort by media type first, kill screen recordings and huge videos, then use search terms like “receipt,” “meme,” “whiteboard,” “parking,” and “screenshot” to find junk that doesn’t always sit neatly in one album. It’s less fancy than a cleaner app, but it catches a lot of clutter without handing the whole library over to automation.
Cleaning a phone that uses iCloud Photos is different from cleaning one that stores everything locally. If storage is the main issue, check Settings > Photos and turn on Optimize iPhone Storage before mass-deleting, because that may free space without removing the originals from your library. Then delete the obvious junk after you have a separate backup, not just iCloud sync.
