What Should I Do First To Recover Files From Hard Drive?
My hard drive suddenly stopped opening, and I’m worried I may lose important photos, work documents, and other personal files. I need help figuring out the safest first steps for hard drive data recovery without making the damage worse.
I wouldn’t freak out yet. I’ve had drives look “empty” and still pulled a lot back, as long as I stopped using the disk right away.
First move, stop writing anything to it. No game installs. No big downloads. No dragging folders around. When a file gets deleted, the file system often marks the space as free first. The old data may still be there until new data lands on top of it.
What usually responds well to recovery software
  1. files deleted by mistake
  2. Recycle Bin already emptied
  3. a quick format
  4. a partition gone missing
  5. files gone after a crash or bad shutdown
Different story if the drive is making noise. Clicking, grinding, beeping, random disconnects, stuff like that. I’d stop there. Those are the cases where more power-on time sometimes makes it worse.
If I were starting fresh, I’d try Disk Drill first. I used it on a normal accidental-delete mess and it was easy enough to get through without babysitting every step. It handles deleted files, formatted disks, damaged file systems, and external HDDs or SSDs. The preview tool helps, since you can check whether a file still opens before you restore it. On Windows, it gives you up to 100 MB free recovery.
How I’d do it
  1. Install Disk Drill on a different drive. Do not put it on the drive you’re trying to save.
  2. Plug in the problem drive.
  3. Open the app and pick the affected drive.
  4. Hit “Search for lost data.”
  5. Let the scan finish, even if it feels slow.
  6. Use filters or search so you’re not digging through a mile of junk.
  7. Preview a few files first. I always do this, saves time.
  8. Choose what you want back.
  9. Restore everything to another drive.
That last step matters more than people think. If you recover onto the same disk, you risk overwriting other files you haven’t pulled out yet. I learned this the dumb way once.
Check the easy stuff before you spend an hour scanning
Look in the Recycle Bin. Check OneDrive. On Windows, look at File History. On Mac, check Time Machine.
I’ve seen people run deep scans for half a day, then notice the missing folder was sitting in a synced cloud directory the whole tiem.
Other tools people use
  1. PhotoRec, free and stronger than its rough interface suggests. Downside, filenames often come back messy.
  2. UFS Explorer, solid for external drives and trickier cases, though it feels more aimed at people who already know what they’re doing.
If the drive won’t show up at all, or it has physical symptoms, I’d skip home recovery. At that point a recovery lab makes more sense. Software won’t repair damaged hardware.
First thing, figure out what kind of failure you have. This matters more than people think.
If the drive spins up, shows in BIOS or Disk Management, and stays connected, you still have a decent shot with software recovery. If it clicks, beeps, disappears, smells hot, or freezes your PC when plugged in, stop powering it on. At that point I would not keep testing it. More spin-up time sometimes means less data later. On this part I agree with @mikeappsreviewer.
Where I differ a bit, I would make a byte-for-byte image of the drive before running lots of scans if the files matter. Scan the image, not the original, when possible. On Linux, ddrescue is the usual pick. On Windows, some recovery tools also support disk images. This matters most for unstable drives and drives with bad sectors.
Quick triage:
  1. Try a new cable, new USB port, or a different enclosure.
  2. Check Disk Management, not File Explorer alone.
  3. See if SMART info shows warnings like reallocated sectors or pending sectors.
  4. If the drive is healthy enough to read, clone it first.
  5. Recover files to a different drive, never back onto the same one.
For software, Disk Drill is a solid first pass if the disk is readable. I like it more for previewing and sorting than for miracles. If the file system is damaged or files were deleted, it does well enough for most home cases. If the drive has a lot of bad sectors, I would still image first. That part gets skipped too often.
Also, do not run CHKDSK yet if your goal is file recovery. People do this early and then wonder why filenames turn into a mess or folders vanish. Repair tools fix structure, not your priorities.
If you want a clean guide for hard drive file recovery steps, this thread is useful:
how to recover deleted files from a hard drive
Short version, stop using the drive, test connection stuff, check if it is logical or physical failure, image first if data is important, then run something like Disk Drill on the copy. If the drive is noisy or keeps dropping out, skip DIY. Labs are expensive, but so is making it worse. Thsi is where people usualy lose the most data.
First thing? Do not keep retrying the drive over and over like Windows is suddenly gonna change its mind on the 12th attempt.
I mostly agree with @mikeappsreviewer and @jeff, but I’d add one thing before jumping into scans or recovery apps: figure out whether the problem is the drive letter / mounting issue, not the files themselves. A lot of people see “can’t open drive” and assume total data loss, when sometimes it’s just a corrupted mount, bad enclosure, or permission weirdness.
My order would be:
  1. Stop using the drive immediately
  2. Try the easiest hardware checks first
    • different USB port
    • different cable
    • different enclosure if it’s an external
    • different computer
  3. See if the drive is detected by the system
    • Windows: Disk Management
    • Mac: Disk Utility
If it shows the correct size there, that’s actually a decent sign.
One place I slightly disagree with @jeff: imaging first is ideal, yeah, but for average home users that can get complicated fast. If the drive is stable and readable, sometimes a straightforward recovery scan is the more realistic first move. If it’s unstable, then yes, clone/image before doing anything heavy.
Also, don’t click “format”, even if the computer suggests it. That popup has baited way too many people lol.
If the drive is readable enough, Disk Drill is a pretty practical option for hard drive data recovery because it lets you preview files before restoring them. That matters more than people think. You want to know your photos or docs are actually intact before spending time copying everything out. Just install it on another disk and recover to another disk too.
For a simple walkthrough and a solid Disk Drill review, this video is worth a look:
watch this Disk Drill recovery guide and review
One more thing people skip: if the drive is making clicking, buzzing, scraping, or beeping noises, stop. No scans, no CHKDSK, no “one last try.” That’s lab territory. DIY is where people turn “recoverable” into “welp.”
So yeah, safest first step is really triage. Confirm whether it’s a connection/mount issue, a logical file problem, or actual hardware failure. That tells you what not to do next, which is half the battle tbh.
Before anything else, check whether the drive is actually failing or just not mounting properly. I agree with @jeff, @sterrenkijker, and @mikeappsreviewer on avoiding repeated retries, but I’d push one extra first move: if the drive is external, test it without the enclosure if possible. A lot of “dead drives” are really bad USB-SATA boards.
A few things I would not do right now:
  • do not run CHKDSK
  • do not accept a format prompt
  • do not copy random files onto it “to test”
  • do not keep unplugging/replugging if it clicks or vanishes
What I’d do first:
  1. Listen to it. Normal spin is one thing. Clicking, chirping, beeping, or spin-down loops mean stop.
  2. Check if BIOS or Disk Management sees the drive and reports roughly correct capacity.
  3. If visible, try to grab the most important files first, not everything.
  4. If browsing fails but the disk stays online, use recovery software.
On software, Disk Drill is reasonable for this kind of situation.
Pros:
  • easy preview of recoverable files
  • good for deleted files, damaged file systems, lost partitions
  • simpler than some pro tools
  • not magic on physically damaged drives
  • deep scans can take ages
  • Windows free recovery limit is small
If Disk Drill finds your files, recover them to a different disk only. If it finds nothing useful, competitors like PhotoRec or UFS Explorer can sometimes see different things. If the drive is unstable, though, I lean more toward imaging or a lab than repeated DIY scans. That’s the one place I slightly disagree with the “just scan it first” mindset.
