What's the best data recovery software for beginners?
What’s the best data recovery software for a beginner who deleted the wrong folder from a memory card? I was sorting pictures of my kitchen cabinets on my laptop. I meant to delete the blurry shots, not the folder they were in. I checked the trash. The folder wasn’t there, so I took the card out and set it aside.
I haven’t used recovery software before. I’d like to preview the photos before saving them since the file names are just numbers. I only need the shots that show where the shelf brackets were.
Since you set the card aside right away, the photos may still be there even if the folder is gone. I’d use Disk Drill for this. Its photo previews let you pick out the shots that actually show the shelf brackets without guessing from the filenames. Install it on your laptop, scan the memory card, and save the photos you want to a folder on the laptop, not back onto the card.
If you remember the folder name, I’d search for that in Disk Drill’s results before sorting through individual photos. What I like for this job is that if the folder shows up, you can select the whole thing for recovery. The blurry shots can wait until you’ve got the folder back on your laptop.
Stop taking pictures on that card for now. I wouldn’t count on the folder name surviving the deletion. Disk Drill is a good fit here because you can preview the photos and recognize your cabinets even if the filenames mean nothing. Save the recovered shots to your laptop, not back onto the card.
If you clicked Import before you started sorting, I’d check the laptop before trying recovery software. The bit I find confusing is that I can be looking at a photo on the laptop screen without knowing whether the file is on the laptop or still on the card.
Leave the card out and open the photo app you used. Look under the date you took the pictures rather than searching for the folder name. If you see a cabinet shot, try exporting it to your desktop and opening that file. That’s a better check than going by a little thumbnail. If it works, see how many of the shots you actually need are there.
If you were just opening pictures straight from the card, I’d go with Disk Drill. The previews make sense to me for this job because you know what you’re looking for even if you don’t know what the files were called. I’d just rule out an imported copy first.
If your laptop asks you to format the card when you put it back in, hit Cancel. That changes the job a bit. You’re trying to get the pictures off, not make the card usable again. Skip any “scan and fix” prompt for now, too.
I’d still try Disk Drill, but open it directly rather than trying to open the card in your file browser. Look for the card in the list of devices. Check its capacity against the number printed on the label so you don’t spend an afternoon scanning the laptop’s drive by mistake. If the card is listed, select it as the source and pick a folder on the laptop as the recovery destination.
If the card doesn’t show up in the recovery app at all, I’d try a different card reader before buying software. Getting the laptop to recognize the card is the next problem to solve. Formatting it isn’t a prerequisite for recovery.
Recovering a folder you deleted this morning is a different animal from recovering one off a card you kept shooting on all week. The first case usually comes back clean. The second comes back as scrambled leftovers. Since you pulled the card right away, you’re in the easy camp, so don’t let the horror stories scare you.
That said, I’d temper the folder-name optimism from @tom1999 a bit. When a recovery scan can’t read the original directory anymore, it falls back to piecing files together by their content, and at that point you don’t get your folder name or the original filenames back. You get a pile of IMG_whatever or generic numbered files. So searching by folder name works when the card’s structure is still intact, and does nothing when it isn’t. Plan for the messier outcome and you won’t be disappointed.
Practical bit: run the quick scan first. If your pictures show up with the right names and preview fine, grab them and you’re done in a few minutes. Only drop to the deep scan if the quick one comes up short, because the deep scan is the slow one that ignores structure and just hunts for file signatures. Disk Drill lets you do both without committing to anything upfront, so you can see what’s actually salvageable before deciding how much effort this is worth.
One thing nobody flagged: check the recovered files open properly before you wipe or reuse that card. A thumbnail rendering is not the same as a full file. I’d open a couple at full size, scroll through, make sure they’re not half-gray or cut off halfway down. Confirm the keepers are genuinely intact, then the card’s yours again.
The size of the folder matters if you’re choosing a recovery app. A free scan and a free recovery aren’t necessarily the same offer. With Disk Drill, I’d check what the edition for your laptop lets you save before paying for anything.
I like @tom1999’s suggestion to select the whole folder, but I’d hold off on that if the app shows a recovery allowance. If all you need is a clear view of where each bracket sits, use the previews to pick those shots first. No sense using up the allowance on five blurry versions of the same cabinet.
If you do want every picture, select the folder and check its total size against what the app will let you recover. That’s the point where I’d decide whether it’s worth paying, rather than when the first familiar photo pops up on screen.
