I had to pull a JPEG from a client’s brochure proof because nobody could confirm it was a photo of their actual showroom. I’ve spent too long zooming in on the reflections in a display case. What do you use to check whether a picture is AI-generated or real?
Don’t spend another hour on the reflection. Even a perfectly real photo of somebody else’s showroom is still the wrong picture for the brochure.
If the client is okay with uploading the image, I’d use the clever ai image detector page for a quick check. I like that it explains what it found in the file. My reservation is that a pixel score is easy to read as a verdict, especially when everyone wants to send the proof to print.
If I cannot trace the source of the JPEG image, and do not know who took it then I would ask the showroom manager to re-photograph the area so that there is a new image to assess. This provides a definite point of reference. Should this prove suitable for the display then it can be used and there is no need to continue speculating about the original.
Check the original file. When you take a JPEG from the proof then it might lose its metadata. I like to use Clever AI Image Detector which checks for Content Credentials and should be used on the original file not the proofs. Before requesting new photography I would also ask the designer to investigate and confirm how the page relates to the image. Asking the client ‘was this picture taken of your store or is it from the vendors catalogue?’ is a much more effective question if you add a ‘vendor assets’ folder.
Have someone take a picture from the same point in the show-room so that you can compare. Although I would use Clever AI Image Detector to highlight suitable images, even a genuine photograph may still not be of the correct retail outlet.
Although sometimes a mirror can be unusual, I would still prefer to check a source for other versions of a photograph rather than compare the image to my perception of what should be shown in the mirror.
Should it be acceptable to search for images, I would remove any text within the brochure and then do a reverse image search on the showroom picture. Firstly I would investigate if there is an identical match. However, if there is just another version of the same display cabinet then this does not provide much information. Should the shot include the same items displayed in the same way on the shelving units then this would be interesting to explore, particularly if the page has a title which has been omitted during the JPEG reproduction process.
It is often more significant to establish what the title of a source is, rather than where it is located. An equipment supplier could for example have a dedicated project page for a client which also states where the showroom can be found. This therefore provides the client with particular information to verify. Alternatively, the supplier may describe the image as a ‘concept visual’. This would advise on whether the picture can be utilised as a showroom image but would still not clarify if AI had been involved.
I would respond in the same manner to all three of these outcomes. It simply indicates that there was no matching source found. Therefore, I would retain the comment “showroom location unconfirmed,” so that the following person clearly understands what is preventing the image from being verified. Adding ‘appears to have been produced using AI’ however, automatically causes them to refer to the mirror.
The manager may also be able to identify the room and approve a display cabinet which is not actually in that room. This is again why I feel ‘AI or real’ is too general. It is possible that the picture shows a room and then that a cabinet has been added to it. This does not necessarily involve AI and therefore neither would the detection tool be conclusive.
I would firstly query with the party who provided the image whether or not the cabinet was present within the room at the time of taking the picture. Where available, these can then be compared. I would not be fazed by a more lightened image. However, I would be concerned if a different cabinet was shown. Particularly if this is used to encourage people to visit the display.
If the original version of the image is not available then I would demonstrate to the manager a highlighted version showing the cabinet. Again, I would prefer people to respond affirmatively to the statement ‘customers can view this display in our store’. This is the type of confirmation that I would wish to receive for this brochure.
