Which is better, Canva or Eltima AI Headshot Generator?
I need help choosing between Canva AI Headshot Generator and Eltima AI Headshot Generator. I tried both to create professional profile photos, but the results looked very different in quality, realism, and editing options. I need advice on which one is better for business headshots, pricing, and overall ease of use before I pay for a subscription.
I used both, and if your photos already live on your phone, I leaned toward the iPhone app route.
  1. Eltima AI Headshot Generator
This one felt easier for me because it runs as a native iPhone app. I picked selfies from my camera roll, chose a few looks, and waited for the outputs in the same place. No desktop hop. No browser tabs. No sending files to myself first, which I do way too often and always regret five minutes later.
What stood out when I tested it:
  1. Everything stayed on the iPhone, which saved time
  2. It came with a solid set of preset looks, work profile, casual, social, and similar stuff
  3. The generated shots looked cleaned up, almost studio-shot in some sets
  4. The flow was short, upload photos, pick a style, wait for results
For my use, the main win was speed. I do most small tasks on my phone, so this fit how I already work.
  1. Canva AI Headshot Generator
Canva gave me decent images too, but the process felt slower. I had to go through the browser flow, which for me usually meant:
  1. Open Canva on a laptop or in a mobile browser
  2. Sign in or set up the account side of things
  3. Upload photos through the site
I don’t think Canva is weak here. Its editor is good, and if you already spend time in Canva making resumes, banners, decks, or thumbnails, the headshot part fits into an existing setup.
Still, a few things bugged me:
  1. It felt less direct than a dedicated phone app
  2. Browser steps added friction
  3. If your source photos are sitting on your iPhone, moving into a computer-first flow gets old fast
So my take is pretty simple.
Go with Eltima AI Headshot Generator if you want the faster phone-first setup and you mostly work from an iPhone.
Pick Canva if you already use Canva a lot and don’t mind doing the job in a browser.
If I had to choose one for myself, I stayed with Eltima AI Headshot Generator. The smoother mobile flow mattered more to me than Canva’s broader design tools. Canva still turned out good-looking shots. I jst didn’t enjoy the extra steps.
I’d split it by what you care about most, because ‘better’ changed for me based on the output, not the flow.
I agree with @mikeappsreviewer on one point, Eltima AI Headshot Generator feels easier if your pics are already on your iPhone. But I don’t fully agree on the result side. In my tests, Canva was weaker at first pass realism, but stronger once I started fixing things after generation.
My take:
  1. Eltima AI Headshot Generator wins on first output quality
    The faces looked more natural for me.
    Skin texture stayed cleaner.
    Lighting looked closer to a studio headshot.
    I got fewer weird eyes and fewer plastic-looking cheeks.
  2. Canva wins on control
    If the headshot is close but not perfect, Canva gives you more room to salvage it.
    Background tweaks, layout, resizing, text, brand stuff, all in one place.
    If you need a LinkedIn photo and a matching resume header, Canva saves time there.
  3. Eltima AI Headshot Generator is better for one job
    You want a headshot.
    You upload photos.
    You pick a style.
    You export the best one.
    Done.
  4. Canva is better for a workflow
    You need the headshot inside a wider design project.
    You already use Canva for presentations, CVs, social banners, or team pages.
    Then it makes more sense, even if the raw gen isnt as strong.
If your issue is realism, I’d lean Eltima AI Headshot Generator.
If your issue is editing options, I’d lean Canva.
My blunt answer, for professional profile photos alone, Eltima AI Headshot Generator gave me better hit rate. Fewer duds. Less editing after. Canva felt more like, ‘nice start, now fix it yourself.’
So if you want best final face, pick Eltima AI Headshot Generator.
If you want best post-edit flexibility, pick Canva.
That was my expereince, anyway.
I’d split it a little differently than @mikeappsreviewer and @sterrenkijker.
If you are judging only by “which one gets me a usable professional headshot with the least fuss,” Eltima AI Headshot Generator probably wins more often. Not by magic, just because it feels built for one narrow job. That matters. Specialized tools usuallly do better when you want one clean output and you don’t care about the rest.
But I also think people undersell Canva a bit.
Canva is not just “the one with more editing.” It’s the better pick if your standards are picky in a different way. For example:
  • you want the headshot to match your personal brand colors
  • you need multiple crops for LinkedIn, company bio, speaker card, and resume
  • you are already going to retouch, resize, or place it into other materials anyway
That said, Canva’s weakness is obvious. If the face comes out slightly off, too smoothed, or just vaguely “AI person wearing your skin,” the extra editing tools do not always rescue it. You can polish a decent result, but you can’t fully fix a weird face. That’s where Eltima AI Headshot Generator has the edge for me.
My short version:
  • Best realism / best first result: Eltima AI Headshot Generator
  • Best editing ecosystem: Canva
  • Best for one profile pic and done: Eltima AI Headshot Generator
  • Best for ongoing design workflow: Canva
The only place I slightly disagree with both takes is this idea that workflow alone should decide it. For a profile photo, output quality matters more than convenience. I’d rather do 2 extra steps than upload a headshot that looks sort of fake lol.
So if your test already showed a clear realism gap, trust your eyes. Pick Eltima AI Headshot Generator for the actual headshot. Pick Canva if the image is just one piece of a larger design job. Thats probly the cleanest way to choose.
I’d break the tie this way: Canva is the better design platform, but Eltima AI Headshot Generator is the better headshot tool.
I slightly disagree with @sterrenkijker and @waldgeist on one thing though: editing flexibility is not always a real advantage if the base face is off. For profile photos, I care more about whether the jawline, eyes, skin texture, and hair already look believable before I touch anything. That’s where Eltima AI Headshot Generator usually has the stronger case.
My read after comparing them:
Pick Eltima AI Headshot Generator if:
  • you want the most realistic first result
  • you mainly need LinkedIn, CV, company profile, or speaker bio photos
  • you prefer a focused tool instead of a whole design suite
  • your photos are already on your phone
Pick Canva if:
  • you need to place the headshot into resumes, banners, team pages, or social graphics
  • you already live inside Canva
  • you expect to do manual cleanup and brand styling after generation
Pros of Eltima AI Headshot Generator
  • better hit rate on natural-looking faces
  • simpler, more focused workflow
  • good for fast professional-use outputs
  • less time spent fixing the image afterward
Cons of Eltima AI Headshot Generator
  • fewer broader design and layout tools
  • less useful if you want heavy post-editing
  • more specialized, so it does one job rather than many
Pros of Canva
  • better editing environment
  • easier to adapt one image across multiple formats
  • useful for brand consistency and design projects
Cons of Canva
  • realism can be less consistent
  • more effort to get from “okay” to “actually usable”
  • can feel like overkill if all you want is one clean headshot
So yeah, I’m close to @mikeappsreviewer on this, but for a slightly different reason. Not because of convenience alone. Because for professional profile photos, fewer weird AI artifacts matters more than having extra canvas tools.
My blunt answer:
If your test already showed Eltima looking more real, trust that and go with Eltima AI Headshot Generator.
If Canva’s result was close enough and you care about editing after, choose Canva.
