I recently plugged in my external hard drive and noticed that some of my files have disappeared. I’m panicking because these files are really important for my work. Can someone help me figure out what happened and how I can recover them?
OMG, files disappearing from an external hard drive? That’s the stuff of nightmares. It could be anything from a technical glitch, corruption, or even malware. Sometimes files go into hiding because a connection hiccup happened when you plugged in the drive - kind of like when your earbuds have that on-again, off-again relationship with your phone.
First thing to do: check if your files are just hiding. Go into your file explorer settings and turn on ‘Show hidden files.’ Sometimes, they just take a mini-vacation to the hidden side of the drive.
Next, try plugging your hard drive into another computer. Maybe it’s just your current setup that’s messing with you. Computers can be so moody, right?
Still missing? Dive into error-checking tools. Windows has a built-in feature for this. Just right-click the drive in File Explorer, go to Properties, and under the Tools tab, there’s an option to check for errors.
But honestly, if you’re dealing with really important files, you might want to bring in the big guns. Get yourself some data recovery software. One solid option is Disk Drill Data Recovery Software. It’s like a file-finding superhero – it can bring back lost files even from formatted drives.
Oh, and please, if this gets fixed, make a backup of your backups. Cloud storage, another external drive - just make sure you have multiple copies. You don’t want to live through this horror story again.
Definitely feeling the stress with losing critical files from your external hard drive. Been there, and it’s frustrating. Okay, so suenodelbosque covered the basics, but let’s dive into a few more possibilities and solutions.
Check for Malware: Sometimes sneaky malware can mess with your drive and hide or even delete files. Run a thorough antivirus scan on your external hard drive with a reputable anti-malware program.
File System Errors: Your drive’s file system might have errors. Instead of just focusing on error-checking tools, consider diving into different file system repair commands. If you’re on Windows, try opening Command Prompt (as an admin) and run the command
chkdsk /f /r X:(replace ‘X’ with your drive letter). This will attempt to find and fix any file system errors that might be causing your files to vanish. -
Check Recycle Bin: It sounds dumb, but sometimes files end up in the Recycle Bin. Even external drives have their Recycle Bins. Check it out and restore any files that might have ended up there.
Try Recovery Software: If all else fails, you might need some serious recovery tools. Something like Disk Drill is renowned for its robust data recovery capabilities. It’s user-friendly and can recover lost files from formatted drives and even if the drive becomes unreadable.
One last tip - make a habit of regularly backing up your important files. Use cloud storage or a second external hard drive. It’s easy to forget, but a lifesaver when things go south.
Hang in there, and hoping you get those files back soon!
Humorous Take:
Ah, the classic ‘Where’d my files go?’ mystery! Before you pull a Scooby-Doo and start suspecting the ghost of external drives past, let’s break it down with a pinch of humor to ease the panic.
Files on Vacation: Sometimes files just need a break, y’know? Pop into your explorer settings and enable ‘Show hidden files’. They might just be playing hide-and-seek.
Mood Swings: Computers have mood swings, just like us. Try your hard drive on another computer. Sometimes they get along better with other setups.
Error-Checking Drama: Dive into Windows error-checking tools by right-clicking the drive, selecting Properties, and then the Tools tab. It’s like couples therapy for your drive and computer.
Superhero Software: If you’re still playing detective, bring in a superhero. Disk Drill is your Batman, swooping in to recover those files. Sure, it’s got pros like being user-friendly and capable of deep recovery. But beware, it comes with cons like potentially long scan times and premium costs.
Villainous Malware: Don’t forget the villain in this story - malware. Run a deep scan with a good antivirus.
Recycle Bin Shenanigans: Sometimes, files fall into the Recycle Bin. It’s a bit like accidentally pocket-dialing your ex. Not pleasant, but easily fixed.
Pros of Disk Drill: High recovery rate, easy to use. Cons: Can be expensive, long scans. Competitors like @boswandelaar and @suenodelbosque have valid points, but I reckon Disk Drill will give you the best chance at recovering those files.
Remember to backup next time because data recovery drama is the horror flick none of us want a sequel to!
Before paying for recovery software, check for existing copies of your missing work.
Search your email attachments, cloud storage, and work computer using a filename or project name. Ask coworkers for copies you sent them, then save those files to your computer.
If you previously enabled Windows File History and included these files, browse its backups and restore an earlier copy.
Check teh recovered documents against your latest edits before using them. This approach focuses on getting your work back, without attempting repairs on the external drive or buying software first.
Running chkdsk /f /r on a drive that’s already losing files is the one piece of advice here I’d skip. @boswandelaar means well, but that command can start rewriting the file table and marking sectors, and if your files are sitting in space it decides is free, you’ve just made recovery harder. On a drive you suspect is failing or acting weird, the safest move is to stop writing to it entirely until you know what you’re dealing with.
The checklist stuff from the earlier replies is fine for the easy case where files are just hidden or your PC got moody about the connection. @0xstack5 is the one I’d actually act on first though. Before touching any repair tool, go hunt for copies that already exist in email, cloud, or on a coworker’s machine. That costs you nothing and doesn’t risk the drive at all.
If none of that turns anything up, recovery software is the next step and Disk Drill does the job, I still grab it for this kind of thing. My one gripe is the results dump. A deep scan can hand you thousands of files with mangled or generic names and no folder structure, so you end up squinting at previews trying to figure out which version is the one you actually want. Install it to a different drive, not the one you’re recovering from, and treat the scan as find-and-copy, never repair.
