Why Did My Partition Disappear, And How Do I Recover A Lost Partition?
One of my hard drive partitions suddenly disappeared after a restart, and now I can’t access important files that were stored on it. Disk Management shows the space differently than before, and I’m afraid of making things worse by trying random fixes. I need help figuring out what may have caused the lost partition and the safest way to recover the partition and data.
Deleted partition? Slow down first
I ran into this once, and the main thing I learned was simple. Speed helps less than restraint. When a partition vanishes, the layout is gone, but your files often still sit there. What ruins recovery is the stuff people do right after, not the original mistake.
What I’d do, in order
  1. Stop touching the drive.
If you keep using it, you start writing over the spots where your old files still live. So don’t make a new partition. Don’t format the unallocated area. Don’t copy random files onto it. Leave it alone.
  1. Open Disk Management before trying any fix.
I’ve seen cases where the partition looked gone, but Windows had only dropped the drive letter. In that case, assigning a letter brings it back fast. If Disk Management shows the area as Unallocated, then yeah, the partition was most likey deleted.
  1. Pull your files off first.
This is the part people skip, then regret. Even if your end goal is to rebuild the partition, get the important stuff out first. Recovery software is the safer move.
I had the best luck with Disk Drill. It picked up deleted partitions, kept folder names and filenames more often than I expected, and let me preview files before I saved anything. That preview step matters. You know fast whether the scan found the real data or a pile of junk.
If the drive was acting weird before the partition disappeared, make a full byte-for-byte image first. Scan the image, not the original disk. I learned this the hard way on an old external drive with bad sectors. Second scan was worse than the first.
  1. Try partition repair only after your data is safe.
If you want the partition itself back, TestDisk is the usual free tool people point to, and for good reason. It’s good at rebuilding lost partitions and fixing partition table messes. Still, it is not beginner-friendly. One wrong pick in there and your recovery job gets uglier.
So I wouldn’t touch TestDisk until the files I care about were already copied somewhere else.
  1. Recreate the partition last.
If recovery got your files back and the original partition won’t come back cleanly, then make a new partition in Disk Management, do a quick format, and copy your recovered files back over.
Stuff people miss
If you noticed the deletion right away and stopped, your odds are usually decent.
If you already made a new partition in the same space, or formatted it, recovery gets harder. Some of the old file system info might be gone by then, and file names or folder structure can come back messy, or not at all.
SSDs are also rougher in these cases. TRIM can wipe deleted data sooner than a hard drive would. It does not always fire the instant a partition gets deleted, but I wouldn’t count on getting much grace time.
My take
I’d ignore repair attempts at first and focus on the files. Once the data is safe somewhere else, then mess with rebuilding partitions. Doing it in that order gave me the best shot at getting things back without making the hole deeper.
First, don’t repair anything yet. I agree with @mikeappsreviewer on the “stop writing to the drive” part. That matters most.
A partition after a reboot usually “disappears” for a few common reasons. Broken partition table. File system corruption. Drive letter loss. Failing HDD or SSD. Bad shutdown. Buggy update. USB enclosure glitch too, if this is external.
What I’d check next is the drive’s health, before doing a long scan. Use SMART data with CrystalDiskInfo or the drive maker’s tool. If you see reallocated sectors, pending sectors, read errors, or warning status, clone the disk first. Don’t keep hammering the original. This is where people mess up.
I slightly disagree with going straight into partition repair tools. On unstable drives, repair attempts sometimes make the layout worse. Data first, structure later.
If the disk looks healthy, run a partition scan with Disk Drill on another drive, save recovered files to a different disk, not the same one. If Disk Management shows RAW instead of NTFS/exFAT, that often means the partition still exists but the file system got damaged. Different problem, same rule. Recover the files out first.
Also check if the disk switched from MBR to GPT weirdly after BIOS or UEFI changes. I’ve seen this once. System rebooted, partition looked gone, but the partition style mismatch was the real issue. Rare, but it hapens.
For a clean walkthrough, this step by step lost partition recovery guide covers the process in a way most people follow without making things worse.
If you want the short SEO version, use this:
Recover a deleted or lost partition fast. Learn how to check Disk Management, scan with Disk Drill, restore files safely, and rebuild the partition without overwriting your data.
One more thing. If this is an SSD, time matters more. TRIM cuts recovery odds fast. Stop using it now.
If Disk Management changed how that space looks after a reboot, I’d also check whether the partition is simply offline, hidden, or missing its file system mount point, not just deleted. That gets overlooked a lot. @mikeappsreviewer and @suenodelbosque already covered the big “stop writing to it” rule, which is right, but I don’t fully agree with treating every case like a straight deleted-partition scenario.
A few things to verify first:
  • In Device Manager, see if the drive is throwing hardware errors
  • In DiskPart, run list disk and list volume to see if Windows still detects a volume that Disk Management is presenting weirdly
  • If it’s an external drive, try a different USB port/cable/enclosure. Sounds basic, but yeah, basic stuff causes stupid problems
  • Check Event Viewer for disk, ntfs, or volmgr errors right after the reboot
If the partition shows as RAW, that often means the partition entry exists but the file system metadata is damaged. Different recovery path. If it shows Unallocated, then partition table damage or deletion is more likely.
My order would be:
  1. Check SMART / hardware health
  2. If unstable, clone first
  3. Scan with Disk Drill or similar and recover files to another disk
  4. Only then decide if rebuilding the partition is worth it
Also, if you want a decent roundup of best data recovery software for lost partitions and deleted files, that thread is worth reading before you install randm junk.
One more thing people forget: if this was your system drive, a Windows update or fast startup hiccup can make things look more broken than they are. Don’t format it “to test.” That’s how people turn a recoverable mess into a worse one.
One thing I’d add to what @suenodelbosque, @voyageurdubois, and @mikeappsreviewer already pointed out: check whether the partition was only hidden from Windows, not actually lost.
A few cases I’ve seen after reboots:
  • volume lost its drive letter
  • partition got marked inactive/offline
  • storage spaces / dynamic disk weirdness
  • BitLocker locked volume showing up differently
  • external drive enclosure reporting bad geometry
I actually disagree a bit with jumping straight from “missing partition” to “deleted partition.” If Disk Management changed the display, that does not always mean the partition table is toast.
What I’d verify:
  • diskpart then list volume
  • mountvol to see if the volume still has a GUID mount point
  • reagentc /info if this was near recovery/system partitions
  • BIOS/UEFI still seeing the same drive capacity
If the volume exists but has no letter, that’s a quick fix. If capacity is suddenly wrong, think hardware, adapter, or firmware glitch before recovery theory.
About Disk Drill: good choice for file-first recovery, especially if you want previews and less command-line pain.
Pros
  • easy interface
  • good for scanning missing partitions
  • previews help confirm recoverability
  • decent for non-experts
  • not the cheapest route
  • deep scans can take ages
  • like any recovery app, results drop hard on TRIMmed SSDs
  • not a magic fix for failing hardware
My view: recover files first with Disk Drill if the disk is stable, but if the drive size or SMART looks abnormal, stop and image/clone before anything else. If it’s encrypted, degraded, or making noises, software recovery may be the wrong first move.
Check your backups before you try to fix the partition. From another computer, look for your most recent files in your cloud storage or on your backup drive. If you synced the folder, check the cloud recycle bin too. Restore the files to a seperate drive, then open a few and check the dates against your last edits. If anythng is missing, list those files and leave the original disk untouched.
Before you run a single scan, make sure you actually have somewhere to put the data. This sounds obvious but it trips people up constantly. You need a second drive at least as big as the one that’s acting up, both for a clone and for saving whatever gets recovered. If you’re on a laptop with one drive and no external handy, you’re stuck, because saving recovered files back onto the same disk is exactly the overwriting everyone above warned about. So sort that out first.
I mostly agree with the clone-first advice from @suenodelbosque, but I’d add that a clone only helps if the drive is readable enough to finish the copy. On a disk with lots of pending sectors, a plain clone can stall or take forever. If it’s genuinely failing, a sector-by-sector image with a tool built to skip bad spots beats a normal clone, and you scan that image. Point Disk Drill or whatever you prefer at the copy, never the patient.
The thing nobody’s really said: a recovered file list is not the same as recovered files. You can get back a clean folder tree with all the right names and still find half the documents open as garbage, especially bigger ones that were spread across the disk. So before you wipe anything or rebuild the partition, open a real sample. A few photos, a couple of the important documents, not just thumbnails. @cyberpixel5891 is right to check dates against your last edits, I’d go further and confirm the files actually open and aren’t truncated. Only once you’ve verified real, working data do you touch the original disk again.
