Wifi 6 vs 6E for home network upgrade?
I’m upgrading my home network and I’m stuck between buying a Wifi 6 or Wifi 6E router. I have several newer devices but not all support 6E yet, and I’m not sure if the extra 6 GHz band is worth the higher price. Can someone explain the real-world benefits, future-proofing, and whether Wifi 6E is actually better for streaming, gaming, and smart home use in a typical suburban house?
Wifi 6 vs 6E comes down to three things for home use: your devices, your neighbors, and your budget.
Quick breakdown
  1. Bands and speeds
    Wifi 6
    • Uses 2.4 GHz and 5 GHz.
    • Great for mixed devices, older phones, smart home gear.
    • Plenty fast for gigabit internet in most real setups.
    Wifi 6E
    • Adds the 6 GHz band on top of 2.4 and 5.
    • 6 GHz has more clean spectrum and wider channels, so lower latency and more consistent speed.
    • Shorter range than 5 GHz, and walls kill it faster.
  2. Device support
    6E only helps devices that support 6 GHz.
    • Newer laptops, some Android flagships, a few newer iPads and motherboards.
    • iPhones still stuck on Wifi 6, no 6E.
    • Most smart home devices are 2.4 GHz only.
    So if 80 to 90 percent of your stuff is Wifi 6 or older, the 6 GHz band sits unused most of the time.
  3. When Wifi 6 is enough
    Go Wifi 6 if:
    • Your internet is 1 Gbps or less.
    • House is small or mid sized and crowded neighbors are not a huge problem.
    • You mostly stream, game, and video call on a mix of older and newer gear.
    • You want a good router without paying a premium for 6E.
    Good Wifi 6 routers handle 4K streaming, gaming, and a bunch of devices without issues if placed well.
  4. When 6E is worth it
    Go Wifi 6E if:
    • You already have several 6E devices, or you upgrade phones / laptops often.
    • You live in a dense apartment or condo where 5 GHz is a mess from neighbor networks.
    • You care about low latency for things like competitive gaming, local game streaming, VR streaming, or large file transfers between local devices.
    • You plan to keep the router 4 to 6 years and expect more 6E gear soon.
    6 GHz helps most in short to medium range, same room or next room.
  5. Router placement and actual performance
    Many people upgrade from Wifi 5 to Wifi 6 and get huge gains simply from:
    • Better radios and antennas.
    • Better CPU in the router.
    • Smarter handling of multiple devices.
    Bad placement kills any benefit of 6E.
    • Central location.
    • Avoid inside cabinets and behind TVs.
    • For bigger homes, mesh with multiple nodes often beats one “monster” 6E router stuck in a corner.
  6. Use a wifi survey app
    Before spending a lot, map your current network.
    A tool like analyzing and improving your WiFi coverage with NetSpot helps you see:
    • Signal strength in each room.
    • Noisy channels from neighbors.
    • Where you need a mesh node or better placement.
    Do a survey with your current router. Then upgrade and run it again. You see real gains instead of guessing.
  7. Simple rule of thumb
    • Tight budget, mixed devices, normal use: get a solid Wifi 6 router or Wifi 6 mesh.
    • Tech heavy home, many new devices, dense area, plan to keep it a long time: Wifi 6E makes sense, especially if price gap to Wifi 6 is small.
If you tell us your internet speed, home size, type of walls, and how many 6E devices you own right now, people here can point to specific models that fit better.
Short version: unless the price gap is small or you’re swimming in 6E‑capable devices, Wifi 6 is usually the smarter buy right now.
@chasseurdetoiles already covered the big picture (devices / neighbors / budget) really well, so I’ll hit some stuff from a slightly different angle and push back on a couple points.
1. Think in “clients per band,” not just “do I have 6E devices?”
Even if most of your stuff is Wifi 6 or older, a 6E router still gives you this layout:
  • 2.4 GHz: smart plugs, bulbs, random IoT junk
  • 5 GHz: older phones, tablets, TVs, consoles
  • 6 GHz: your handful of newer laptops / high‑end phones
That separation can keep your 5 GHz band from getting congested. Where I slightly disagree with @chasseurdetoiles is the idea that the 6 GHz band “sits unused” if only 10–20% of your clients support it. In some setups, that’s exactly the point: you’re carving out a VIP lane for your best devices.
But… this only matters if:
  • You actually have a bunch of active devices at the same time
  • You do things like big file transfers, local streaming, or lots of calls / gaming
If your “heavy” usage is just Netflix and YouTube, Wifi 6 on 5 GHz is already bored.
2. Range & walls: 6E looks better on spec sheets than in real houses
6 GHz sounds amazing until you hit:
  • 2 walls away: speeds drop fast
  • Different floor: often completely useless
If you’re in:
  • Small apartment or 1–2 rooms: 6E can be noticably nicer for latency and consistency.
  • Larger house, especially with brick / concrete / old plaster: your 6 GHz cells are tiny “bubbles” and you’ll need mesh nodes to really benefit.
If you’re not planning a mesh system, I’d lean hard toward a really good Wifi 6 router instead of a single Wifi 6E “flagship” stuck in a corner.
3. Internet speed vs local speed
Ask yourself what you actually care about:
  • If your internet plan is ≤ 1 Gbps and you mainly care about online speed:
    Wifi 6 is totally fine, and often indistinguishable from 6E in practice.
  • If you do stuff inside your network:
    • NAS backups
    • PC‑to‑PC file transfers
    • VR streaming (Steam Link, Virtual Desktop etc.)
    • Local game streaming from PC to handheld
Then 6E can shine, because:
  • Cleaner spectrum
  • Wider channels like 160 MHz without neighbors stepping on you as much
  • Lower latency in same‑room scenarios
But again, you need:
  • 6E clients
  • Nodes in the right spots
  • Real workloads that benefit
4. Upgrade strategy, not just “what’s better”
Practical way to decide:
  • Skip 6E and go Wifi 6 if:
    • You have mostly Wifi 5 / 6 clients
    • Your walls are thick and house is mid‑to‑large
    • Money matters and the 6E premium is high
    • You’re not a “copy terabytes over wifi” type of person
  • Go 6E if:
    • You already own a couple 6E laptops / phones or upgrade gadgets often
    • You live in a dense building and 5 GHz is a channel soup
    • You’re OK paying more for “future‑proof-ish” gear and keeping it 4–6 years
    • You’re planning mesh anyway, so 6 GHz can be a high quality “last hop” for nearby rooms
I wouldn’t overpay just for the label though. A solid midrange Wifi 6 router will beat a trash Wifi 6E router every single day.
5. Before spending: map what’s actually happening
People buy 6E, then put the router in a closet behind a TV and wonder why it sucks.
Grab a survey tool like NetSpot and actually map your existing coverage:
  • Walk around your place
  • Check signal strength, channel use, dead zones
  • Look for where neighbors are hammering 2.4 / 5 GHz
Using something like visualizing and boosting home WiFi coverage gives you data instead of vibes. Do a quick survey now, then again after the upgrade so you can actually see whether 6 vs 6E made a difference.
6. Slightly hot take: sometimes the cheaper 6E wins
One place I’ll gently disagree with the “only get 6E if X/Y/Z” logic:
If:
  • The price difference between a good Wifi 6 and an entry‑to‑mid 6E model is small
  • Both are from reputable brands
  • You expect your next phone / laptop to support 6E
Then I’d absolutely grab the 6E so your future devices have a clean lane. Just don’t throw extra money at the “flagship gaming RGB spaceship” router unless you actually need its features.
SEO‑friendly summary of your situation
Upgrading your home network and stuck between Wifi 6 and Wifi 6E?
Wifi 6 gives fast, reliable performance on 2.4 GHz and 5 GHz for most homes, especially if your internet speed is under 1 Gbps and you have a mix of older and newer devices. Wifi 6E adds the 6 GHz band, which can deliver lower latency and cleaner, high‑speed connections for supported devices, but its range is shorter and it costs more. For most people, a strong Wifi 6 router or mesh system is the best value. Choose Wifi 6E if you already own multiple 6E devices, live in a dense area with heavy WiFi congestion, plan to keep the router for several years, and want to take advantage of the extra 6 GHz band as more of your gear gets upgraded.
If you drop your internet speed, size of your home, and how many 6E devices you actually have right now, it’s possible to narrow this down to a very obvious choice.
Short version: pick based on layout and upgrade horizon, not just device count.
Where I slightly diverge from @himmelsjager / @chasseurdetoiles:
  • I care more about where your heavy‑use devices sit than how many are 6E.
  • I’m also a bit less bullish on “future proofing” with 6E if you’re likely to replace the router again in ~3 years.
1. Map your actual use
Ask yourself:
  • Where do you game / video call / transfer files?
  • Are those devices mostly in the same room as the router or one wall away?
  • Is your house long / L‑shaped / multi‑floor?
If your “important” devices tend to be close to where you can place the router, 6E has a real shot to shine. If they are scattered through multiple walls and floors, 6E becomes a niche bonus at best unless you go mesh.
I’d actually prioritize a Wifi 6 mesh over a single Wifi 6E “beast” in a bad spot.
2. Practical decision matrix
Try this angle (different from what’s already been said):
Choose Wifi 6 if:
  • Your router location is not flexible (corner, closet, far end of the house).
  • You are not planning mesh right now.
  • You have maybe 0–2 6E devices, and they roam the whole house.
  • Your internet is ≤ 1 Gbps and you rarely move huge files locally.
Choose Wifi 6E if:
  • You can put the router in a central room where you actually use high‑end devices.
  • You already run or plan a mesh system so short‑range 6 GHz cells make sense.
  • You regularly do latency‑sensitive or high‑bitrate local stuff:
    • PC or VR streaming
    • NAS backups over wifi
    • Large project files between laptop and desktop
  • The price jump to a decent 6E model is small enough that you would not regret it in 2 years.
I slightly disagree with the idea that 6E is mostly for dense apartments only. Even in a suburban home, 6 GHz can be very nice if your main workstation / TV / console is in the same room, because you get a “quiet” band even without lots of neighbor interference.
3. Router quality vs radio spec
One thing both replies touched on, but I’d push harder:
A good Wifi 6 router with solid firmware and stable drivers is worth more than a flashy Wifi 6E that has:
  • Janky firmware updates
  • Overheating issues
  • Weak QoS or bad band steering
If you do go 6E, avoid bottom‑of‑the‑barrel models. I would rather buy:
  • High‑mid Wifi 6
    than
  • Lowest‑tier Wifi 6E
Because day‑to‑day stability (roaming, not dropping calls, no random slowdowns) matters more than peak link speed that you see once in a benchmark.
4. Why “future proof” can be overrated
You’ll see a lot of “future proof with 6E” takes. My counter:
  • Wifi tech cycles are fast. Wifi 7 is already shipping.
  • ISPs often bump speeds or change CPE in that same time.
  • You may end up wanting Wifi 7 or a new mesh anyway for better interference handling and MLO features.
So if 6E is significantly more expensive in your market, I would not overpay just for the logo unless:
  • You already benefit today, or
  • The price gap is genuinely small.
Otherwise, a robust Wifi 6 system now plus a later jump to Wifi 7 might serve you better.
5. Quick look at NetSpot for planning
If you are on the fence, this is one place where a survey tool like NetSpot actually helps make the call instead of guessing.
Pros of using NetSpot:
  • Visual heatmaps so you see where 5 GHz is already strong or weak.
  • Channel usage data so you know if 5 GHz is really “crowded” or just fine.
  • Lets you test “what if I put the router here?” before you commit.
Cons of NetSpot:
  • Desktop focused, so not as convenient as a simple phone app for some people.
  • Has a bit of a learning curve if you want to use the more advanced views.
  • You need to spend 20–30 minutes walking your place to get meaningful data.
Run a quick survey with your current router:
  • If 5 GHz is already strong and neighbor interference is moderate, Wifi 6 is usually plenty.
  • If you see saturated 5 GHz channels and lots of overlap, 6E starts to look more attractive.
6. Concrete rule of thumb
If I had to compress it for a typical home upgrade:
  • Most people:
    Good Wifi 6 router or Wifi 6 mesh, spend saved money on:
    • Better placement (mounts, cabling)
    • Extra node for coverage
  • Power users or dense environments:
    Wifi 6E router or mesh only if:
    • You can place nodes sensibly
    • You own or will soon own several 6E clients in your main rooms
    • The cost difference is not painful
If you share your approximate square footage, number of floors, wall type (drywall vs brick/concrete), ISP speed, and how many 6E‑capable devices you have right now, you can get a very specific “6 vs 6E” call.
